this is how i view freescan .csv logs using open office. i'll start from the very beginning...
1. with freescan running and operational, click "start" in the CSV Logging box. name your file and click "open". after your done logging click "stop".
2. run open office. click "file", "open". find your scan and double click it. then this box will pop up...
Attachment 7510
in the "separator options" section, make sure only the "comma" box is checked and click "ok".
3. your file should open and be readable now. here are some other things you can do to the file to help viewing...
click the line between the number 1 and 2 row and drag it down to make the row taller like this...
Attachment 7511
then right click the number one row and click "format cells". click the "alignment" tab and select "wrap text automaticly"
Attachment 7514
now you can start shrinking the columns down so they all fit on the page without panning. click the line between the columns (a,b,c,) and drag them to make them smaller, like this
Attachment 7515
finally, click the number 2 row, click "window" and "freeze". this will lock the top row on the top of the page so you will always know what column you are viewing.
Attachment 7512
that should just about get it. if theres something i left out or need to clarify, let me know. good luck!
