Ingenuity and determination
This has been on your want to do list for some time for you. I so glad to see the process moving ahead towards completion in the impala. Looking forward to seeing the impala when the transplant is complete.
Slow and steady... day one, wiring disconnected, fluids drained, trans out, crossmember out, exhaust disconnected, header removed...Attachment 39132
Thanks man... so excited' and yet so nervous of what am I missing' what will go wrong' etc etc...
I know that feeling I'm waiting on grage time myself to get my build done. Your is a whole different animal. With procharger not making a kit yours will be one of a kind. I wouldn't be nervous you have people working on your build that helped with your previous build. Your motor has been dialed in and you have taken care of it. Having the custom procharger bracket for the impala it looks like the belt is lined up in the photos from posts you have made. Now setting the new heart beat between the frame rails sounds like there will be modification need for clearance for the procharger. With having a full frame. How the frame needs modification to allow the procharger clearance. I look at the possibly of reclocking the procharger to see if it would clear the frame with out modification. You and the guys that have and are helping you out have thought about position and what is possible to be done with the procharger to clear the frame that didnt need to happen with the Camaro.. You should be able to use the impala wiring harness. It's been awhile since I have looked at an impala accessory drive and how it different from the camaro's.
Sorry for the rambling on @popo8.
.Attachment 39135Attachment 39136Attachment 39137Attachment 39138
Now this is awesome to see! Sorry I haven’t been on in a long time. Can’t wait to see it running.
